sli power requirement
lukem9962
hey there im building a new pc and wanted to know how many watts i need to power for instance gtx 680 sli ? i currently have enermax 650w modular psu but i think that might not be enough
Below are great choices. The 850 watt model is the lowest that I would consider with your confirmation, or you can get the 1,000 watt model for extra peace of mind. Were it me, I'd go for the beefier wattage, but either choice is solid.
EVGA 850 G2
$144.99 - $25 (rebate card) = $119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438018&cm_re=evga_850_g2-_-17-438-018-_-Product
EVGA 1000 G2
$174.99 - $30 (rebate card) = $144.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438010&cm_re=evga_1000_g2-_-17-438-010-_-Product
Gtx 680 needs at least a 550wt psu to run.
If you SLI Get a 700 wt psu and You it is enough. www.game-debate.com/hardware/?gid=1543&graphics=GeForce%20GTX%20680%20SLI
ok :) fanboyism aside what are evga psu like ? who makes them ?
