Question sli problem please help
Sep 19, 2019
5
hi i got 2 geforce asus 2080 rtx graphic cards im having problem playing video games like fortnite rust and other stuff dont render properly from distence i dont know how to fix this should i remove 1 graphic card? i tested turning of sli i didnt work.
dotas1
974
46
5,440
163
SLI most of the time just cause problems. You would be fine with just one card. Also if you do want to play every game to it's max settings with high fps in 1080p/1440p then I would sell the 2 2080 and get a 2080ti as someone else said earlier.
Sep 19, 2019
5
how much do u think i would get for them they are brand new ive used them for 2 weeks
dotas1
974
46
5,440
163
That depends where you are from, if there is a high demand and of course, how lucky you are.
If they are brand new as you said, they should sell very close to the price you paid for them. For example in my country the cheapest 2080 has 646€. I would sell a bit below 600. Maybe 585-595.
