SLI + Ultrawide Monitor
alexisvx
59
Hi all,
I am buying the Asus PG348Q (IPS/3440x1440/100hz). I currently have a GTX 970 and thinking of also upgrading my GPU along the new monitor.
The question I have is whether I should go for SLI or for the GTX 1070 (I can't afford the 1080).
I have read about SLI VS 1070 in terms of benchmarking etc and for my needs these options are the same. In terms of cost, I would much rather go for SLI but I am not sure how it will perform for this monitor.
Thanks
My Rig:
Windows 10
Motherboard: Asrock Z97 Extreme 4
CPU: i5 4690k 3.5Ghz O/C to 4.6Ghz
GPU: GeForce GTX 970 SSC
CPU cooler: Noctua NH-D14
PSU: EVGA 750W ATX12V
RAM: G.Skill - Ripjaws X - 4x4GB (DDR3 2133)
Case: Fractal Design Define R4
Hi alexisvx,
A single card will always be a smoother experience over multiple cards. I'd definitely recommend a single 1070 over 970s in SLI. Also, because the monitor has a high resolution of 3440x1440 it means you'll reach the 3.5GB VRAM limit of your 970 which will cause stuttering and other issues (970s aren't true 4GB cards if you weren't aware). SLI doesn't stack the VRAM so you won't have 7GB (8GB) VRAM.
Hope this helps,
Leemon
Hi alexisvx,
Hope this helps,
Leemon
