SLK900u and what fan?
Montoya
23
I'll be looking for cooling that would enable a 2.4c to OC to around 3.0 - 3.2Ghz. Seems as though the tornado is the best for performance but i want something quieter than that baby. What are peoples recommendation for a fan and what size should i go for, 80mm 0r 92mm?
thanks.
Yes the Tornado is brutal, but you can't beat it's performance. In general, the bigger the fan the less noise- however it is more like a different kind of noise, so instead of getting the high pitched scream of the tornado you get a low droning sound... Either way, get a 92mm if you can. Try www.nexfan.com
