S shalehha Commendable Aug 17, 2018 163 0 1,680 Oct 18, 2018 #1 Will there any trouble if i use gpu with pcie 3.0 in pcie 2.0??? I am worried there will be a lag etc.
Solution rgd1101 Oct 18, 2018 pcie 3.0 have higher bandwidth. your question was if it works. yes it work.
rgd1101 Don't Moderator Nov 7, 2011 73,301 3,852 176,290 Oct 18, 2018 #2 nope. it will work fine. Upvote 0 Downvote
WildCard999 Titan Moderator Jul 18, 2014 21,771 1,935 93,640 Oct 18, 2018 #3 Yes it will work. Upvote 0 Downvote
S shalehha Commendable Aug 17, 2018 163 0 1,680 Oct 18, 2018 #4 So there will be no issue?? If yes, why pcie 3.0 exist?? For what??? Thanks Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 73,301 3,852 176,290 Oct 18, 2018 Solution #5 pcie 3.0 have higher bandwidth. your question was if it works. yes it work. Upvote 0 Downvote Solution
