[SOLVED] Slow LAN on PC but fast WiFi on Phone?
zombie1801
27
My PC on LAN is 100mbps but my phone on WiFi is 400mbps. My pc is also having so much trouble loading websites, to the point where it takes so long i get an error code on the website. Sometimes ill actually load into it, but its a huge problem. I cant test my pc with WiFi because I dont have a WiFi motherboard. It happened a few hours ago, i was just viewing the port forward section in my router seeing if i wanted to port forward a game and now my internet is like this. I dont know what I did, or even if I did anything. Everything was working fine and then this happened.
Allow me to end your frustration.
I had this same problem and was driving me CRAZY!!!!
I had my internet company out here at least 10 times over the past 6 months. Even had ASUS issue an RMA on my motherboard, and through countless tweaking totally screwed up my adapters tweaking settings.
It was none of that it is a Windows problem.
Open a command prompt with Administrator privileges ( Click start and type CMD, right click Command prompt and run as admin)
Type:
netsh int tcp set global autotuninglevel=disabled
I actually went forward and changed that to 'normal', so you can also use the below (which is what im running now.
netsh int tcp set global autotuninglevel=normal
after either it should say "OK"
then type...
Type:
then type
ipconfig /renew
let it do its thing
Then type
ipconfig /flushdns
Enjoy your internet speeds!
Reactions: zombie1801
Type:
then type
ipconfig /renew
let it do its thing
Then type
ipconfig /flushdns
WOW I THANK YOU SO MUCH!
