Slow ping rates and loss of connection to a computer in th..
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.windowsnt.misc (More info?)
Hi,
We have a windows 2000 server (running active directory) in our network
which we use as a fileserver. Previously it has been running fine but
recently (in the last month or so) when we are trying to navigate the file
system sometimes explorer freezes and we loose the connection to the
machine. This usually only lasts for 1-10 seconds and if we refresh we get
the connection back. So it seems that periodically we loose connectivity to
this machine or the speed of the connection slows down.
When I ping the server in question I am getting an average ping rate of 3 ms
instead of <10ms (which I believe we previous always got) with spikes of up
to 20ms. My theory is that these spikes correspond to the down time.
Actually I just checked and saw that the ping rates to other machines in the
network showed results like 1-3ms, when previously I think they always
showed <10ms - however we don't get this problem with the other computers.
Could this be a router problem?
The disk are a bit fragmented and we have 19% space on the Windows
partition. The server has been running for several years without too many
changes.
Has anyone seen this before?
Most grateful for any help.
Here is an example of pinging the problem machine.
Reply from 192.168.0.2: bytes=32 time<10ms TTL=128
Reply from 192.168.0.2: bytes=32 time=1ms TTL=128
Reply from 192.168.0.2: bytes=32 time=13ms TTL=128
Reply from 192.168.0.2: bytes=32 time=3ms TTL=128
Reply from 192.168.0.2: bytes=32 time=5ms TTL=128
Reply from 192.168.0.2: bytes=32 time=2ms TTL=128
Reply from 192.168.0.2: bytes=32 time=17ms TTL=128
