Question Slow signal detection through DiplayPort ?
7medd
57
9
545
4
I have an MSI 251rx bought a month ago. I noticed that if I connect it to my PC through HDMI, it works fine. If I use DP it is slow to detects signal . It starts to display when boot is over it reaches desktop. Also this comes with a red VGA signal on mobo. Everything works fine afterwards. No performance flaws at all.
This doesnt happen when I reboot PC (monitor doesnt turn off) and then I can see bios access options .
I tried to change monitor settings , disable Eco mode , disable enable autoscan, I manually installed the driver from official site, change DP port on GC ... no success
I cant find another DP cable in my country to try it.
https://postimg.cc/bDVXd7Kg
I had a 144Hz monitor before, connected through DP and never had a this problem.
Any clue ?
I had a 144Hz monitor before connected through DP an naver had a similar problem
Any clue ?
It sounds like the monitor is the issue, Om monitors with drivers have issues with not display till a driver wakes it up another words it's working the way it knows, the driver initialized the screen via dp normal via hdmi
Reactions: 7medd
7medd
57
9
545
4
Problem is RMA is not availble in my region either .. I thought it would be a firmware problem of the monitor and might be solved through update or so .. but I cant find how to do this.
