Slow SSD copy speed
Apr 22, 2018
12
My SSD is a crucial mx500 500gb. The problem is crystal disk shows 560 read and 502 write speed which is good. But when i copy file from this SSD to the same SSD it have like 100-200 mb/s copy speed and is just as fast as my old hdd. On hardisksenitel it shows the trim is supported and turned on.
And the status of the disk is perfect also I have 182gb free so its propably not because of the space. Any tips guys please?
NORMAL. don't get hung up on benchmarks. My 850 Evo Pro does 200 MB/sec transferring a VM to another folder from SSD to SSD
no problems here. the tests they run are not always what your file I/O is like
Crucial has their own test software, you can also use Parkdale which is free, but don't bother, you are fast as you are going to get.
go to userbenchmarks and run the online thing, it will tell you how your ssd is performing. http://www.userbenchmark.com/
Not normal at all when a old HDD is fast as my SSD and also there is a video on yt copying files on 850evo mine crucial is pretty much the same and the speed was like 500 mb/s so this aint it anyways thx for help.
^+1 I really doubt your HDD is actually that fast.
Also, the rated speed for SSDs (500 MB/s in your case) are typically for unrealistic scenarios involving high queue depth sequential transfers, and aren't reflective of what you're going to see during typical use.
