Slow usb wireless adapter speed
ammrzman
17
Hi, i bought my PC a year ago with a TL-WN725N 150Mbps USB adapter. At first it was working fine, but now im getting 3.5Mbps at best (my internet speed is 10Mbps). Most of the times it hovers around 0.5-2Mbps. What puzzles me more is the fact that i even tried installing a PCIe wireless adapter from a different PC (which the adapters were working fine) but the problem still persists. So i thought it might be software issue, but i dont know what.
Solutions I've tried but to no avail:
1. Uninstalling and reinstalling the drivers. (both adapters)
2. Plug the adapter to different ports. (both adapters)
3. Use the "winsock reset" command.
Can anyone please help. Thank you
try to reset the router and see , if it stays then seems...
try to reset the router and see , if it stays then seems you PC is infected and someone is using the internet on your pc , try a clean install and see. you tried 2 cards , and both are slow , this is not a hardware problem .
