How full is the drive?Im using samsung 860 evo,after benchmarked it shows read : 562 write : 396 which is very low for that ssd.Why did it happen ?
Is this a change from when the drive was brand new?106/500 gb used
Those numbers are fine.Im using samsung 860 evo,after benchmarked it shows read : 562 write : 396 which is very low for that ssd.Why did it happen ?
What benchmark did you use? And what settings did you use with that?Im using samsung 860 evo,after benchmarked it shows read : 562 write : 396 which is very low for that ssd.Why did it happen ?
Moral of the story:I had something similar happpen to my 860. The write speed dropped to 330. The culprit was userbenchmark which for some reason caused the write speed to go dowm. It may mave been to do with Samsung's tubrowrite but once powered down the drive reverted back to its correct benchmarks speeds.
Too right, not using that thing again. One quick search on the net revealed many unhappy usersMoral of the story:
Don't use userbenchmark to test your drives.
