Hey all,
The new desktop Ryzen APUs are almost here and i am in big dilemma on how to proceed with all this crazy pricing in GPUs that seem to be getting even worse in 2018.
My current options if i buy a GPU that i can afford are:
a) Gigabyte Radeon RX 560 2GB for 131 euros.
b) Gigabyte GeForce GTX1050 2GB Windforce OC for 146 euros.
c) Palit GeForce GTX1050 Ti 4GB Dual OC for 178 euros.
All 3 GPUs come with a 6-pin power supply connector so they can be better overclocked and achieve more value from the GPU and with 2 fans for lower noise and better temperatures.
So if i go and buy today a GPU i am stuck with a low end GPU and CPU and i will probably have to upgrade both sooner or later, probably starting with the CPU, so i guess it will be better to buy the cheapest one on the list; the RX-550. Will the 1050 Ti give nice performance in games in 2019 paired with a zen+ or zen2 CPU? My guess is not so much, a 1060 or 1070 will boost performance by far with the newer and much better CPU and GPU prices will be much better than today (at least i hope they will 😛).
But there is a completely different approach! Maybe i can just upgrade the CPU to a Ryzen 5 2400g. It's iGPU won't be as good as an RX-560 which is the cheapest on my list, but at least i will have decent graphics for now (at only around 180 euros) and a much better processor than the one i currently have (plus the fact that my ram will run at 3000MHz which is supported with Ryzen according to my mobo QVL).
If i buy this APU i will have time to raise more money for a 1060 and maybe even see the prices drop around summer-autumn in GPUs.
Well there is catch here i think. I am concerned that i will be stuck with a CPU with only 4 cores/8 threads and with only 6MB L2/L3 cache, in comparison to a 1st gen ryzen 5 1600 that has 6 cores/12 threads and and 3 times more L2/L3 cache (3/16Mb) at the same price. So i am afraid that my GPU will be bottlenecked by the Ryzen 5 2400g and i will end up needing to upgrade the CPU as well in 2019.
I am trying to find the best futureproofing scenario with the minimum money spent but it's very hard given all those factors. I will try to resell anything i upgrade, but the resell value often is not that good, so let's leave it out of the equation.
Any ideas?
Current computer setup:
amd a8-9600, asus prime a320m-k, 2*4GB corsair vengeance LPX DDR4 3000MHz
(currently running at 2133MHz), Corsair CX500 PSU
Any ideas?
