Hi, I'm searching for a small 2x-120mm water cooler with a max. depth of 40mm.
I have a nzxt h210i case and asus strix gtx 1070.
Been unable to find a fitting water cooler and i started thinking about getting a radiator with a depth of 30mm and getting 2x120mm fans with a depth of 10mm.
Are there any fans this small and even if, would they be able to support the radiator properly?
thanks in advance
thanks in advance
