Hi All,
I'm helping my dad revamp their small business network which is 10+ years old. I have experience with basic linux servers and basic networking so I hope my questions and statements are detailed enough to give the community some good stuff to go off of. Please let me know if you have any questions and thanks in advance for the help.
This small business network is very old and in dire need of upgrading. Their network still runs off of a Cat5 ethernet hub with manual IP configurations done at each and every computer around the office. There's no firewall other than the basic one built into the company's T1 modem (also old). The company also has a windows server that's only purpose is to host their accounting software and allow for multiple logins (so people can be entering invoices/checks, etc at the same time). What I want to do is this:
1. Replace the hub with a smart switch (24 or 26 port should be plenty)
2. Add in a router that can handle DHCP for the wired connections and act as a firewall between the WAN and LAN (I'm thinking of setting up a basic computer with ClearOS but maybe I should just buy a basic hardware router--what does community think?)
3. Add in a wireless access point off the switch that the router (above) will manage and will force certain restrictions over (for example, guests logging into wireless can use the internet but not access the server)
4. Update the server to a new tower that runs Windows Server 2012 Standard and does a number of things for the LAN that the company never implemented before, such as:
a. Create an active directory that manages the logins of all the client computers (all windows machines) on the network
b. Setup a VPN to allow remote access to the server from the interwebs
c. Setup both some local "server" backups onto USB HDDs that are plugged in, and setup network backups to certain client computers around the network
d. Setup the accounting software server and allow access for both LAN clients and internet VPN logins to access the accounting software
The way the company is set up now basically has no access control and no active directory. The server sits on the network and as long as a LAN computer types in the network IP and maps the server's HDD to a letter (such as the "H:\" for example) that computer has read/write access to the server. Then, these computers install the client accounting software and just configure the client software to the directory of the server files on the server. Then the client accounting program allows them to make changes, work, etc.
Here's my questions:
How much should I have the router manage and how much should Windows server manage? Should I let the router be the WAN firewall and the DHCP server for the LAN? I probably shouldn't have windows server be the router in addition to being the server, but how do I configure the router to maintain the IPs and do DHCP but then have the windows server manage the active directory and manage the staff logins and determine permissions for each of the staff? How do I define to the windows server that it only needs to manage the active directory, and to listen to the router's naming of which computers are on which IPs?
How do the windows clients know that the server is acting also as the access control manager and to listen to the windows server when trying to log into the network?
How do I set up wired guest accounts to give some computers (or some logins) internet access without server access?
If I set up a wireless access point, how do I configure it to listen to the router and again, do I let windows server also manage active directory on the wireless?
If I install carbonite or a similar backup service on the server, is that recommended? What does the community think of options like that?
Will ClearOS play nice with windows server 2012 and can I successfully define what responsibilities ClearOS has versus windows server 2012?
I realize a lot of these questions go beyond community suggestions, so if anyone has recommendations on where I can find out more about windows work domains and active directories, etc, I'd absolutely appreciate it. Thanks all!!
