Small Charms and Damage Effects
G
Guest
Guest
Archived from groups: alt.games.diablo (More info?)
In the deep dark past (read that as before 1.10) there was a REASON one
wanted a bunch of little charms with damage, cold or poison, because there
was something special about each charm being calculated separately in
terms of the time a freeze or poison lasted. IE, though the absolute
damage numbers added up the same on the face, three small cold damage
charms would keep a monster blue longer than one gc. Something similar
applied to poison as well.
Will someone undertake to explain how that works, or doesn't, in 1.10?
Thanks,
Elly
one
there
similar
1.10?
Only as far as poison damage is concerned. It is calculated using a
bizarre formula that takes into account the number of different
sources. As I am not at home now, where I keep this sort of info, I
will leave it to someone else to paint the picture in greater detail,
if you're still interested.
Mickey
"Mickey" <mickeyb@comcast.net> wrote in message
news:1109958353.958750.283340@l41g2000cwc.googlegroups.com...
> one
> there
> similar
> 1.10?
> Mickey
I'm out on the poison issue, but for the cold, IIRC it still works in the
same way.
~1 second chill for each cold charm, or something like that
short
