hi,
So, I just assembled a new PC, it runs extremely well but i observed some small "clicks" when you launch an app under Windows10 - perhaps i am just paranoid and i wanted to know if this is kinda "normal" or it's because it's drawing power, etc.
It seems to happen when there's a "load", i.e. when i launch Mullvad VPN or Word, Excel, Powerpoint, Photoshop, something a bit heavy, makes that "click". nothing strange happens, no warnings nothing, temperatures are good as well.
My hardware:
DeepCool LT 720 AIO - already disconnected all fans one by one, clicks still there
Asus Prime z790-A Wifi
INTEL CORE I7-13700KF 5.4GHZ LGA1700 Processor
SSD Samsung PRO 990 1 TB
Corsair HX1000i Fully Modular Ultra Quiet ATX Power Supply
Tuning done via Asus Suite3 and in BIOS shows the red one, it did the auto tuning thing, etc - runs at 5.5 ghz - no issues and temps are great
There's no other moving hard disk installed inside the case, etc and no mouse clicking as the mouse as "quiet clicks".
Here's the paranoia video, you can hear some "click" sounds at these minutes: 0:30, 0:48, 0:49, 0:50, 0:54, 0:58, 1:03.
www.dropbox.com
-> Question: Could the clicks be simply electrical current running through the transistors of the motherboard and when you launch an app there's more power draw?
Asus support said "It would not be abnormal for the capacitators or transistors to make a similar noise when being stressed. The sound however is more like a mechanical clicking noise from a mouse or fan."
thanks,
Gab
My hardware:
Dropbox
thanks,
Gab
