Question Small display problem
hrisimir
35
Hello I think I have some sort led backlight problem but im not sure since its localized. Here is a picture of it and the monitor model (pretty old one of the first aoc models with g-sync). Should i be worried?.It moves alightly left and right sometimes and its only in that part of the screen.
View: https://imgur.com/a/vZqkL11
since for some reason it doesnt allow me to insert it
That monitor was released in 2015, so you're about a decade into the monitor's life. You might want to take a picture of the screen from a distance for us to see the overall status of the monitor but your monitor would need replacing.
here is a whole screen
doesn't appear noticeable enough to cause any issue with viewing.
are you just concerned about a larger overlying problem or does this abnormality with the backlighting really bother you?
the only "fix" i'd bother with is just getting a new display.
anywhere that offered a repair for this type of malfunction would probably be charging a lot and likely not doing much, maybe just removing the bleeding diode.
Thank uou considering it just randomly disappeared just a miniscular line compar d to the pic my beat amateurish guess it has to do something wih the panel pressure at that particular corner
