Parq Reputable May 25, 2014 26 0 4,530 Feb 21, 2016 #1 Hey guys, I wanted to get my profile setup so I start with my profile picture. When I upload it making sure its 100x100pixles this happens... It also logs me out while im on that page until I get back on to the main site. Any idea why!?
Solution Titillating Feb 22, 2016 Parq : Thanks for the replies guys. The problem still persists. Give it another try; this should be resolved now.
Wolfshadw Titan Moderator Aug 3, 2006 28,221 1,513 133,290 Feb 21, 2016 #2 Usually, it's just communications issues. They occur from time to time (maybe once every month or two). I'd just try again later and if the problem exists, let us know. -Wolf sends Edit: Also, you may want to clear your browser cache and cookies. Upvote 0 Downvote
ssddx Titan May 27, 2009 17,054 5 74,965 Feb 21, 2016 #3 http://www.tomshardware.com/forum/id-2978041/change-avatar.html#17534270 it appears to be a forum bug of some sort as one of the mods tested after it was reported and had the same issue.. we are aware of it Upvote 0 Downvote
Parq Reputable May 25, 2014 26 0 4,530 Feb 22, 2016 #4 ssddx : http://www.tomshardware.com/forum/id-2978041/change-avatar.html#17534270 it appears to be a forum bug of some sort as one of the mods tested after it was reported and had the same issue.. we are aware of it Thanks for the replies guys. The problem still persists. Upvote 0 Downvote
Titillating Expert Ambassador Aug 18, 2014 4,662 5 16,965 Feb 22, 2016 Solution #5 Parq : Thanks for the replies guys. The problem still persists. Give it another try; this should be resolved now. Upvote 0 Downvote Solution
Parq Reputable May 25, 2014 26 0 4,530 Feb 22, 2016 #6 Titillating : Parq : Thanks for the replies guys. The problem still persists. Give it another try; this should be resolved now. Resolved. Thank you guys! Upvote 0 Downvote
