Small, Light, Portable Case
Asyrin
11
So, I'm looking to rebuild my HAF 932 case to something far smaller and lighter. I LAN party about once every two weeks and it's brutal on the giant, heavy case I have. So, I want the smallest, lightest, most portable case that I can get that's still a great case that will fit my components. Here they are:
P8P67 Full ATX Motherboard
Corsair Dominator RAM
2x EVGA GTX 580 in SLI
Cooler Master Silent Pro 1000W PSU
2x Crucial C300 128gb in RAID 0
As small and light as I can get it...designed to be moved around preferably while still generating good airflow.
I don't overclock so the cooling doesn't need to be insane.
Thank you so much in advance!
I'm interested on this too any ideas?
I'd like something made of acrylic with a handle..but i guess i'll have to construct it myself.
You have a full ATX mobo which is obviously a problem if you want small and light. Your smallest choices will be mid towers. I would have recommended an ITX system like the BitFenix Prodigy http://www.bitfenix.com/global/en/products/chassis/prodigy/
Latest posts
