Doing a small upgrade to boost my airflow, ram, and power.
My knowledge of good RGB fans is very limited. I've got some cheap ones at the moment, and they don't seem to do a ton.
For context, the only thing getting hot in my PC is my single-fan graphics card. I can't afford to upgrade it at the moment, so I'm looking to boost everything around it if possible to help cooling.
Some questions I have are:
New Build: https://pcpartpicker.com/list/F8wXrr
Old Build: https://pcpartpicker.com/list/dJ2Nht
- Should I go for RGB fans in my single-fan-hot-GPU situation? Are there good ones out there, as good as Noctua? I just want my case to glow pink, man.
- Is my ram a good choice? I do heavy photoshop, drawing, modeling, etc. Looking for this to be the most important upgrade.
- Will Noctua NH-U12S fit? My partner has a larger case, bought a DH-15 and it barely fit. I know they're different, but both seem to be larger than most. Trying to measure everything perfectly, though I'm not the best at visualizing.
