small usb cooler for windows stick
valhallarising
518
Hi, i got one of these http://x86pad.com/t02.html meegopad similiar to the intel compute stick problem is device is getting very hot . I seen people using 2.5 cm fans on top of them to cool them im looking for a fan that can connect to the usb 5 v to get Power for the fan anybody know if they exist?
So you're planning to draw more power (create more heat) to try and cool it down? You will create the heat internal to the enclosure, and airflow on the outside is bound to be inefficient for cooling. IMNSHO, you're not going to succeed. Even if it does end up feeling cooler oon the outside, it will be hotter on the inside.
