Question Small, very small audio pops every now and then ?
Dec 1, 2021
16
I bought a brand new desktop and every now and then i get these annoying audio pops in my headphones. I used different headphones, and the other audio port and the issue persists. Is there any way to fix it other than the 6 basic steps every other website has listed?
I've done all of those which include:
  • updating audio drivers (there was no update)
  • rollback (nothing happened)
  • switching the format to CD quality
  • disable exclusive mode
RoyAbare
16
Try opening the volume mixer and mute different sources until you identify the one that's causing it (system sounds would be a good place to start). If this yields no results you might have a hardware issue.
Ralston18
And I will add the suggestion to double check that all connections, power, video, audio, peripherals are tightly in place.
Nothing loose/wiggly.
Especially around the I/O panel connection ports and the case panel connection ports.
