Small Water Versus Big Air, Part 3: Cooling Questions Answered
Annisman
1,751
Ditched my Domino A.L.C. for a Xigmatek Thor's Hammer with 2 X Scythe fans. Strapped it on a Core i7 920, bumped it to 4.0Ghz and never looked back.
tkgclimb
524
I was looking at water, then I decided if I really want to do this I'm going to have to spend at least 200 if i want a good, effective, upgradeable system. So I'm going to get the megahalem or the thermalright TRUE extreme. and stay with some sick air.
rpmrush
175
Air is still a better value unless you value noise or lack there of.
Water offers lower noise @ a slightly less extreme overclock, but who runs 4.0Ghz plus everyday.
still using my old thermaltake big typhoon with a few mods - sealed the gaps on the sides for more air pressure and using a 12cm "thick" fan from a dell tower (crazy) and the same type fan to extract air - works a treat :D
kinda proves that when your going water cooling, do it PROPERLY not a pre made kit
if i was to do water cooling, i would go all the way with a modded car radiator, drum for a water sump and a few powerful decent sized pumps to start off with to keep everything sweet, none of this "barely better then stock" bs.
G
Guest
Guest
The corsair h50 is NOT a water cooling solution. Not even close. At best, call it an "optimized" air cooler. The only situation where you would want one is if you need to install a cooler in a tight space. Otherwise, it's higher cost really ruins any value it has.
The_Blood_Raven
2,567
Get a Swiftech H220 in there and it will beat the air coolers pretty well, besides that there are no out of the box water cooling setups that can actually beat high end air coolers by anything meaningful.
Good article though, your best articles are when you take the time to answer these odd questions that are commonly asked by the enthusiast.
As many times as I see bottom-PSU cases like the Antec 300 recommended in builds in the Forum, the lingering question for me becomes, "Suppose I do have a bottom-psu top-panel-fan case. Would that make a difference?" Or, is there ANY situation where the cooling performance of this type of liquid cooler is actually superior to a big air cooler?
skora
1,498
Thanks for listening to the feedback and doing follow ups like this TS. Really gives the community a reason to become involved knowing our unanswered questions get addressed.
G
Guest
Guest
It would be good to see a comparison of the H50 with a push-pull fan setup.
I have an old-style Antec SLK-B case with a side-port fan (intake) that blows air into and through two push-pull 1500 RPM fans with the H50 radiator sandwiched in-between; these fans blow out, not in. The temp drop from a single fan to dual fans is around 7c degrees.
The biggest advantage of the H50 is noise, or lack thereof. My Tenma sound meter records less than 30db within 1ft of the case. Can't say that for any of the other HSFs I've tried (mostly stock).
zodiacfml
1,227
26
19,310
still prefer the liquid cooler as it reduces the need for an exhaust fan, only I should have to match it to a powerful processor for good use of it.
vinshon
29
i have the thermaltake v9 case with 230x230 large top exhause fan, and psu is at the bottom of the case, would the h50 do better for me?
FSC
23
Otherwise fine article but who would use 250w consuming freak CPU in their computer in everyday life? I'd love to see the results of using stocks-speed instead over clocking.
[citation][nom]rpmrush[/nom]Air is still a better value unless you value noise or lack there of.Water offers lower noise @ a slightly less extreme overclock, but who runs 4.0Ghz plus everyday.[/citation]
Air can be very quiet, but it requires that you keep fan speeds low. A good 120 mm fan running at 1000 rpm or less is just about inaudible, but such low speeds mean you can't overclock a whole lot. I'd guess based on my experience that you wouldn't want to pump more than about 150-160 W through a decent 120 mm tower heatsink like the ones used in the review if you keep the fans
theLaminator
127
@vinshon
IMO you should be able to build a custom water setup in that case. Custom water will cool much better than the h50 anyday. Will it cost more than the h50? Yes but if you're gonna do water do water, these little prebuilt kits really don't cut it when comes to shedding heat or noise levels
doomtomb
814
5
18,985
[citation][nom]theLaminator[/nom]@vinshonIMO you should be able to build a custom water setup in that case. Custom water will cool much better than the h50 anyday. Will it cost more than the h50? Yes but if you're gonna do water do water, these little prebuilt kits really don't cut it when comes to shedding heat or noise levels[/citation]
Yep, I started out with a little pre-built kit but now I use a custom built loop to cool my CPU and northbridge/southbridge. Keeps the temp way way down on both. I have a 780i and the northbridge & southbridge have terrible stock cooling and the CPU is a quad core overclocked to 3.75GHz and it still stays icy cold.
thackstonns
230
yeah i would like to see you guys do some loop testing with some danger den stuff. I have a custom loop with an old ehiem pump, danger den waterblock, and a dual 120mm heatercore, and it stomps temps. I reach the limit of the cpu way before I tax the loop.
scooterlibby
195
I just ditched the Domino when a "self-contained" pump burst and spewed coolant all over the VGA's, motherboard, and PSU. It was a nifty little thing, but the Zalman 9700 replacement I got seems to cool better and cost a lot less. Having tried both big air and little water, I really don't see the benefit of little water. If you want liquid, just go full out with "big water" in my humble opinion.
bounty
389
"Defenders of the concept could point out that many cases have significantly more ventilation through the top panel, via two 120-140mm fans or a single larger fan"
You could also argue that a setup like that would help big air as well. I'd like to see you test out the massive fan on the side panel concept, or the top air as you describe to see if those cases really do affect cooling performance. Also, how much value we should put on 120-140mm fans v.s. 80mm fans inside the power supply?
lowguppy
192
ATX case design in general is terrible for airflow, especially when you load it up with extra HDDs and multiple large video cards. Even a single double-slot card functionally cuts the case in half. I've got a custom layout design that would be much better using the same parts, but nothing close to it is produced commercially except for overpriced boutique cases.
