I am going to build a new workstation. I have already chosen all the internal components I need, just having problems finding the right chassis. I am looking for a chassis that will directly fit one of SuperMicro’s X8 E-ATX motherboards measuring 12” x 13” inches, with all the mounting holes used and lined up correctly. I already know of several full tower cases that these boards have been tested in, but what I am looking for is the smallest possible case to house this motherboard in. I travel around a lot and sometimes the PC has to come along, so smallest possible dimensions and a very solid build are the most important things. The Titan650 and akasa’s Omega chassis seem to be about as small as I can find with a good build quality, but their width is not necessary for the SuperMicro Cpu coolers I will be using. Some of the smallest E-ATX cases I have found so far come from Chieftec but the build quality looks very poor. SuperMicro’s own chassis selections are also very compact but way overpriced, and always come with a PSU that I will not have use for, and that adds to the price tag. Any suggestions?
