[SOLVED] Smallest Micro Atx case with 1 Optical drive bay
Dec 2, 2018
Hi I'm out looking for the smallest Micro Atx case with one Optical drive bay, I have not found one so far, the requirements are simply support for a 310 mm Graphics Card (ROG Strix 2080 ti) and compromising on things (like being limited to an SFX power supply and no SLI support) won't matter , Thanks
asoroka
1,200
So 310mm GPU card is not small, you are really gong to need a decent case.
What aesthetic look are you going for?
What is the height of the card, I assume not low profile.
Can you make do with an external DVD?
What don't you like about using a normal ATX tower case?
Dec 2, 2018
I would like a window with my case, i was considering an mITX case, but I need a pci slot for a capture card, the case needs to be under 370mm in height and since it will be a workstation i want to use a 5.25 dock to hold a 9.5mm Optical drive and a 3.5" card reader, any answer will be helpful, thanks
