Planning on a build just unsure if i can find a matching power supply, build as follows:
Core i5 3570k
Gigabyte GA-H77N-WIFI
EVGA GeForce GTX 660 SC 2GB
G.SKILL Ares 8GB(2x4GB) DDR3
SanDisk 120GB extreme SSD
WD Scorpio Blue 750GB SATA2 HDD
Also as per title can someone suggest me a small power supply for this? Is 500W enough? I've looked into TFX and 1U power supplies and 1U ones seems more appealing, as i know nothing about electrical can someone tell me if the voltage and amperes appropriate for a mini-itx? The max height needs to be less than 3". Also can someone also suggest me an appropriate heatsink.....
Thank you SO MUCH in advance
Core i5 3570k
