[SOLVED] Smart Fan 5 problem with Gigabyte X570 Aorus Pro and AMD Ryzen 7 3800XT
Mindraid
Hi just bought a new rig with Gigabyte X570 Aorus Pro.
So normally I want it to be quiet but I have noticed that the fans speed up for a short moment even if I don't do anything in Windows.
So I have started to dig into the Gigabyte software "Smart Fan 5" that can be edited from both Windows (SIV) and from bios.
My problem is that I can change the fan curves in the advanced tab in windows SIV software but as soon as I change fan selection it reverts back to what it was before.
All fans have been set to use VRM mos except the CPU. And I have set it to the selection "Quiet" in tab Auto.
What am I doing wrong? (I want a softer curve)
It seems to be in idle mode around 55 deg C and when stressed with Cinebench it about 72 deg C. I have not overclocked the CPU.
Best regards,
M
My new rig:
  • Gigabyte X570 Aorus Pro (Bios F31q)
  • AMD Ryzen 7 - 3800XT 4.7GHz
  • Noctua NH-D15 (A big fan for the CPU:)
  • Corsair RM750X V2 750W
  • Samsung SSD 970 EVO PLUS 1TB
  • Gigabyte GeForce GTX 1660 OC HDMI 3xDP 6GB
  • HyperX Fury Black DDR4 3600MHz 2x16GB (HX436C18FB4K2/32)
