Question Smart guys, please help. MSI B650 Tomahawk motherboard won't post.
Nov 2, 2024
New build. I haven't attached GPU, etc yet.
No sound when I try to post, but the EZ Debug LED lights "DRAM" and "CPU" are both lit.
I reseated CPU and substituted other DRAM. Same result.
Flashed BIOS. Same result.
Not sure what to try next. I've built PCs before, but am clearly in over my head, as I can't think of anything else to try.
Board: MAG B650 Tomahawk wifi
BIOS: I have flashed E7E26AMS.1H1
CPU: AMD Ryzen 9 7900 - Ryzen 9 7000 Series Zen 4 12-Core 3.7 GHz
MEM: CORSAIR VENGEANCE RGB DDR5 RAM 32GB (2x16GB) 6000MHz CL30-36-36-76
Nov 2, 2024
No beeps with speaker plugged in, but EZ debug lights are still on. Screen just says "no signal" then enters sleep mode.
The pins all look symetric and straight. I was cautious putting the cpu in out of fear of bending them. It helps that AMD is less exposed than Intel, so they look good.
Nov 2, 2024
Well, crud. Is there a way to figure out which one? I got them from Amazon, which has a pretty good return policy, but I don't necessarily want to return the wrong one.
Nov 2, 2024
Ah. Don't have one of those. Well, I'll start by returning the cheaper one (mobo), and cross my fingers.
Even though my problem didn't get resolved, I want to thank you. Here you are online using your abilities to help people who can't offer you anything. I appreciate you walking me through this process.
Someday, when you get stuck in some area of your life, I pray God will provide a person to walk you through that.
Have a great day.
Nov 2, 2024
Oh my gosh! No! I didn't realize there was a separate 8 pin. I put that in, and now it posts! Thank you!
I was about to try to exchange the motherboard. Then I would have done exactly the same thing with the replacement, and had the same problem. It's is embarrassing that the answer was basically "do you have it plugged in?" Thanks for knowing to ask the right question. I seem to be back on track.
