G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I need help. I AM GOING INSANE!
Anyway, here is my problem.
If I install any kind of ATI driver(catalyst 4.9 and earlier versions)
or variations (Omega), smoothing on my monitor fails to work.
What I mean is that if I change the resolution of my TFT to one that
isn't its native resolution the text looks messed up.
Now, when I uninstall all instances of the ATI driver the smoothing
process works brilliantly and I'm able to use the monitor fine on
non-native resolutions.
I've been playing around with settings, installing new drivers for days
now, and its driving me MAD! What else can I do?
One thing I notice which might be a problem (when the ATI drivers are
installed)is that when I go into 'settings' of 'Display Properties' The
second monitor option is there and is stated as default monitor. I feel
if I somehow remove the second monitor(I use a single monitor and do not
have any other connected) this might solve the problem.
My hardware is
MSI K8N Neo Motherboard
Sapphire 9800 Pro
Iiyama E431S TFT
Please someone, anyone, help me. Honestly you will save me from this
slippery road of INSANITY!
My hardware is
Sapphire 9800 Pro
Iiyama E431S TFT
