So i think im going to upgrade my cpu because of BF1
FrostinFire
Commendable
Jun 13, 2016
60
I have an FX 8310 3.5 ghz to 3.7 and its 8 core
and a gtx 1050 ti g1 gaming
8 gb of ram
i have seen people run with this gpu on ultra at 60 -70 fps
And i on high uñtra settings i get 50 to 20 fps drops , and i get lots of stunnerings then i turned on v sync and it seems to help but i still not get those 70 fps even if i put everything on low
Then i was told that the problem was my cpu but i dont have that much bufget to buy one just used it to buy the 1050
so i was thinking on what could fix those stuns. and get better frames without upgrading the cpu?
What about overclocking CPU? Didn't you consider that? If the CPU is a bottleneck then FX 8xxx running at 4.5Ghz should give you at least 25% more FPS and fewer drops. What's your Mobo? Ram frequency? Drivers up to date? Remember to use DDU program to install graphic card's drivers properly.
i have seen benchmarks of playing on ultra at 60-65 fps but i think they were using more RAM but dont you think the problem its the cpu
I can't believe anyone can run ultra on that card unless running a resolution like 720p or less. Even a 1070 would struggle to maintain 60-70 fps at 1080p in BF1. Your CPU does ok in BF1 as the game can utilise all 8 threads and should achieve 50 fps or more if the gpu is up to it.
When you say seen people running, do you mean YouTube? YouTube is full of liars.
do you think upgrading ram will help?
and the gpu its a gtx 1050 ti 4gb OC G1
Im running a 1070 and bf1. I get 140+fps on very high settings
BF1 isn't that GPU demanding. While I don't believe you'll get stable 60fps with a 1050Ti it's a viable card.
You're most likely CPU bound.
OCing the FX and closing and disabling all background programs and utility will help as well.
Ok the 1070 does a little better than I remembered at ultra 1080p. The 1050Ti should be around the 470 in performance
Taken from her http://www.gamersnexus.net/game-bench/2652-battlefield-1-graphics-card-benchmark-dx11-vs-dx12
