I immafrog1337 Honorable Jun 1, 2013 597 0 10,990 Jun 10, 2014 #1 so i wanna switch from hdmi to dual link dvi but i still want audio through my monitor. what cable do i buy for audio? oh yeah, i have a gtx 770
Solution Wolfshadw Jun 10, 2014 Since your monitor likely only has stereo audio, you likely won't notice a difference. I'm not sure why you want to do this. HDMI and DVI should provide the exact same visual experience, If you REALLY don't want to use HDMI for audio, then just get the 3.5mm stereo cable. -Wolf sends
Wolfshadw Titan Moderator Aug 3, 2006 28,223 1,514 133,290 Jun 10, 2014 #2 Verify that your monitor has another audio input for a 3.5mm cable from your motherboard's audio port. -Wolf sends Upvote 1 Downvote
I immafrog1337 Honorable Jun 1, 2013 597 0 10,990 Jun 10, 2014 #3 it does. so i should buy a 3.5mm audio cable? Upvote 0 Downvote
I immafrog1337 Honorable Jun 1, 2013 597 0 10,990 Jun 10, 2014 #4 should i stick with hdmi? would it be better if i used dvi for pc gaming? Upvote 0 Downvote
Wolfshadw Titan Moderator Aug 3, 2006 28,223 1,514 133,290 Jun 10, 2014 Solution #5 Since your monitor likely only has stereo audio, you likely won't notice a difference. I'm not sure why you want to do this. HDMI and DVI should provide the exact same visual experience, If you REALLY don't want to use HDMI for audio, then just get the 3.5mm stereo cable. -Wolf sends Upvote 0 Downvote Solution
