So much trouble with bood device and operating systems!!!!!
ZachGuyTheTechGuy
32
So i have been getting error code: error-0xc00000e9 and after constantly getting that message while getting help from someone, now the message reboot and select proper boot device constantly comes up. I cant fix it and i was trying to get back to the message that says: press any key to boot from cd/dvd grrr why so many problems, i already had trouble with my cpu heat and other NOW THIS!!. Earlier before this my Cd drive was in boot priority number 10 while my hdd was in boot priority number 9 so now i changed it to optical cd drive to 1 and hdd to 2 still no fix with the boot device thing i evenwent to boot menu and selected my cd drive as my boot device GGGRRRRR. Did my cd drive break?
All fixed just My OS getting scratched got a replacement and my first build is working!!!
Yes, License as in product key.
Also, it happened to me once that I was not able to load all Windows files, because the system would automatically boot of my flash drive at restarts during installation, without asking me.
In that case, for me the solution was to remove the flash drive when the system restarted.
Try to reinstall Windows, and when you see that it`s restarting, eject the DVD. Once the system started to laungh, close the tray again.
Next reboot, eject, wait, close tray. Rinse and repeat until windows is installed.
Let me know if this is also your problem.
Do you still have Windows installed? If yes, can you access it?
If you played with the boot order, and that doesn`t work, I would make a boot-able flash drive, and install Windows from it.
That`s how I do it for years now, and you just need to have the license at hand during installation.
I never could fully load all the windows files so i guess no to installed windows and license as in product key?
