3 months old, My personal build,
To cut things short, i was playing some csgo in my PC, then when i was done, i properly shut it down and left the power supply master switch on, which i usually do. Now after a few hours, i noticed that my motherboard rgb lights are not turned on, and there is some orange light flickering on my motherboard (seems grounded), pressed the power button.l, then it wont turn on. So i unplugged everything then left my house. Well i dont know if that will work but what do you suggest i do? Thanks. No current power surges and blackouts.
SPECS:
thermaltake litepower 650 watts
Rog strix b350_F mobo
Ryzen 5 1400 oc'd @3.8ghz
Rx 590
2 tb hdd
120 gb ssd
Aio cooling.
SPECS:
Rx 590
2 tb hdd
120 gb ssd
Aio cooling.
