Hello, I have a i5 6600k OC to 4.6ghz cooled via a cooler master nepton 240m with corsair af120 fans. i CPU stress tested it for 15 mins and it went to temps of 98 degrees, which is very hot for a skylake. It started at 28 degrees. Ive had this cooler for around 2 years now, i used to have AMD so i then switched it over to the intel bracket when changing cpu etc. Im not sure if this bracket isnt fully compatible with 1151 or my cooler is broken, as i didnt even touch the voltages so surely it shouldnt be this high? I live in the UK and my room is semi-hot but this shouldnt make a massive difference. What is going on with my temps, and is it worth an upgrade to a kraken x61 or possibly even go air and get a hyper 212x?
Thanks for any advice you can give,
Rob
Rob
