Software / Hardware problem
Shafaryna
Commendable
Aug 10, 2016
23
This is my problem. I do not know what type of Avg antivirus product my senior install at my pc but the avg is broken. Everytime I open AVG, it ask me to enter product key. So, i try to uninstall it from control panel but it was failed. I also use AVG_Remover.exe and the it was succesful but AVG web tune up is still there. And when I try to install the free one, it also failed. What i am supposed to do? My PC right now keep jammed and I need to restart my PC everytime it happen. I already check all hardware and software problem and only AVG is left. Can someone help me?
You may have to clean out the system of AVG residues before ir can install again. So see if running CCleaner helps, or try a different antivirus.. Avast Free is to me a better option so try it out.
Shafaryna
Commendable
Aug 10, 2016
23
Thanks. Your answer really help me
