Software Problems when using WinTV PVR 150
AK6865
6
So a few years ago I bought this WinTV PVR 150. I tried to hook it up, but I had no luck so I abandoned it. Now, I want to use my WinTV PVR 150 as a capture card for my Xbox 360 (Yep, I play old school). I plugged the card into my PC, got the drivers, etc. But when I got to viewing the capture card (The card acts like a webcam) I got errors and it didn't display anything. I tried using with VLC, no luck. I tried VDub, no luck. I tried DScaler, no luck. I tried XSplit, no luck. Then I ran into the default WinTV software. I don't want to have to purchase this just to find it won't work. What should I do? All errors are displayed below:
VLC -
VLC cannot open ANY capture device. Check the error log for details.
VirtualDub -
No errors, just displays a blank screen.
DScaler -
Can't load Hardware Driver, possibly caused by corrupt installation. Reboot and try again.
XSplit -
Camera is not available. Check to see if it is disconnected or in use by another application.
When I got to WinTV, I get the display from my Xbox but it's coming at less than 1 fps.
