Software to monitor water temps?
Apoca1ypse
56
Hi all.
I feel silly asking this, but can anyone recommend some software that will allow me to check my water temps? I have a probe in my loop, and I can see the temp reading when I am in bios, but I do not know of any free software that will let me check my water temp while in windows.
Any recommendations? I am using an Asus x99 deluxe (in case that matters)
No you cant monitor your water temps because there is no sensor to detect it unless the Cooler has a sensor and a digital monitor. There is no any software to monitor your water temps. You can monitor your CPU temps using Hwmonitor:
http://www.cpuid.com/softwares/hwmonitor.html
Water temps is really not needed in Overclocking. You can monitor your CPU temps correctly as the motherboard and CPU itself has sensors for the socket and different cores of the CPU respectively.
CB :sol:
CB :sol:
I have a temperature probe in my water, which is connected to temp sensor #3 on my motherboard (the Asus x99 Deluxe comes with some 2 pin sockets for attaching temp sensors). I can see the temps for it in BIOS, but I cannot find a program that will let me check temps for things other than CPU and GPU.
I had my fan speed profiles based of water temps for sound purposes, and it's worked a treat so far :)
I have used AIDA64 for monitoring all my temps, but it doesnt monitor well when I run other software to bench and stresstest as it stops updating the temp readouts. It also isnt free (just has 30 day trials)
