[SOLVED] Sofware for thermaltake 750w gf1 ARGB ?
Gojke
Commendable
Mar 29, 2022
19
I couldn't find any video, picture or topic.
Does anyone know or have experience with this power supply, can addressable rgb be set via software, because I see at the output of the power supply that there are 4 pins, but I do not know how it is on the other side of the cable, is there 3 pins for ARGB?
Using this manual for the PSU, you will need a header on your motherboard as suggested in said manual.
The end on the PSU is 5 pin, while the end that tethers to the motherboard will be 3 pin.
