I will be buying a Renogy 100 watt 30A pwm solar kit from amazon along with a Renogy 700 watt pure-sine inverter, and I could definitely use some help as a first timer.
My question is about fuse sizes.
The inverter comes with 4AWG Cables . What size fuse do I need to have between the positive battery terminal and inverter?
Also, I'm starting out with a single 100 watt panel (eventually expanded to 400 watts total) on a 100Ah SLA battery. What size fuse should I use between the panel and controller for now, and when I add more panels (400w) total?
I was also thinking of just using a breaker between batt and inverter rather than a fuse. Is that a better way to go?
