Question Solid State Drive compatibility for Toshiba Satellite L655-S5112
May 24, 2020
Hello guys, I need to know the compatibility options SDD for a Toshiba Satellite L655-S5112, to replace the original hdd,
Let me know your feedbacks,
Thanks !
R_1
Glorious
Ambassador
Welcome to the forums :D
2.5 inch & SATA are the only requirements.
the original drive is a 2.5 inch HDD with a SATA interface getting an SSD in the same form factor should be easy. you could add a drive with more capacity if you wish, the only requirements are listed above
here is a list sorted by price. look to at least a 500GB class drive if you can afford it.
https://pcpartpicker.com/products/internal-hard-drive/#t=0&f=3&sort=price&page=1
this is the drive in my computer just as an example
https://pcpartpicker.com/product/WGZ2FT/kingston-a400-480gb-25-solid-state-drive-sa400s37480g
Reactions: jagpk981
May 24, 2020
R_1 thanks for helping me and for the list, I will check it, Thx so much !!!
May 24, 2020
Thanks !
Everything above is correct.
2.5" SATA III is the only option. Direct drop in replacement for the existing HDD.
Since this will be the only drive, 500GB or larger.
Crucial MX500 would be a good recommendation.
Thx I will take your advice for replace mi old hdd for a new ssd,
