'lo all, (Budget - Not over £1300 = $2500)
Got some free time at the moment and I've decided to build a new gaming system (although my current Radeon 9700 will forever be remembered fondly). Will never need to use SLI or Crossfire (i'm a one card guy) but may learn how to over-clock and hence still need a decent motherboard. In some ways I think this is not an ideal time to buy, R600 not all that far away and Penryn going into production before the end of the year...but hey, i've waited 4 years already!!! .
I intend to get a motherboard that supports 1333MHz in the hope it will cover Penryn (but I know that is a shot in the dark), and if R600 is really that much better I can always purchase it later.
Take a look at my system below, have I made any major mistakes? (I.e. another company that does the same part better and for less????) ALSO....any tips for any low price items I might need....special non-static screwdrivers? X number of cable ties? etc etc (i.e. silly little things you only know you need through experience)
Antec 900 Ultimate Gaming case
Intel Core 2 DUO E4300 1.80GHz
Asus P5N32-E SLi nForce 680 (Socket 775) Motherboard
GeForce 8800 GTS 640MB GDDR3 HDTV/Dual DVI
GeIL 2GB (2x1GB) PC6400C4 800MHz DDR2 4-4-4-12
Seagate Barracuda 320GB SATAII 7200.10
GameXstream OCZ 600W Powersupply
Samsung SH-182MRSMN 18x18 DVD±RW Dual Layer Lightscribe ReWriter
Thank you for any advice you can offer, all views will be carefully considered.
N.b. Should I buy my own fan to cool the CPU?
