My trusty i7-6700K system developed some issues and I need to swap out my motherboard/processor and memory.
The rest of the system will suffice till I get this stuff installed and my "command center" back in operation.
I want to get an i9 13900K which I'll hopefully use as long as I have the old 6700k. I'd also like it to be a 790/DDR5 to keep it relevant for as long as possible.
I don't need tons of USB's, wifi etc...I just want to be able to run the stock 13900k to it's full potential and not hamstring it with inadequate power.
I don't plan to overclock....aside from tinkering maybe once when I get the system.
I do like to buy overbuilt hardware but $500+ for a motherboard is more than I want to spend if I can help it.
I do play some games, but this system is what I use for EVERYTHING...I mean it's my primary teevee, CAD/3d Printing, app development...run VM's...you name it.
What motherboard is adequate? I like the Gigabyte boards but I see people saying the mid and low range ones are not recommended for the 13900k due to weak VRM.
Aside from that GIGABYTE Z790 AORUS ELITE AX seems attractive?
