Solution for wireless audio from desktop PC
cha0sunity
My Dad has asked me to come up with a way for him to play music from his desktop to an outdoor deck. I've been searching but haven't found what I would consider to be a good solution. I know it's possible to use bluetooth, but with an effective range of 30-50 feet and having a wall between the desktop and where he wants to sound, I'm not sure it's a viable solution. I've been looking for a stand alone wifi speaker but haven't really come up with anything that is in my price range or around $100. Does anyone know of something that fits this description, or perhaps an alternate solution. I have considered building a setup from a raspberry-pi but I'm not sure that I want another device to have to troubleshoot.....
Thanks for your help.
http://the-gadgeteer.com/2014/09/02/rocki-play-wifi-streaming-audio-adapter-review/
This Rocki adapter can work with an existing speaker to make it wifi. You are correct that wifi has much better range than Bluetooth.
http://www.amazon.com/oc/echo/ref_=ods_dp_ae
Another solution is the Amazon Echo. It is $99 for Amazon prime members, but otherwise it is over your budget.
