(SOLVED) An Overwatch build for 700 Canadian Dollars...
Deniedstingray
983
Im trying to build a coworker a pc for overwatch and the one i originally made was 8-900 dollars. He wants it to be 6-700 dollars max now.
Im honestly not sure how to go about this. EDIT: Here is what i came up with.https://ca.pcpartpicker.com/list/4HjkkT
Could some of you suggest a few builds?
Thanks guys.
AMD
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor ($136.99 @ PC Canada)
Motherboard: Gigabyte - GA-AB350M-Gaming 3 Micro ATX AM4 Motherboard ($108.99 @ Newegg Canada)
Memory: ADATA - XPG Z1 8GB (2 x 4GB) DDR4-2800 Memory ($93.99 @ PC Canada)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($69.95 @ Vuugo)
Video Card: Zotac - GeForce GTX 1050 2GB Mini Video Card ($153.99 @ PC Canada)
Case: Deepcool - TESSERACT SW RED ATX Mid Tower Case ($49.99 @ Newegg Canada)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($63.99 @ PC Canada)
Total: $677.89
Generated by PCPartPicker 2018-01-02 16:42 EST-0500
Intel
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor ($70.99 @ PC Canada)
Motherboard: Gigabyte - GA-B250M-DS3H Micro ATX LGA1151 Motherboard ($89.99 @ Newegg Canada)
Memory: Kingston - FURY 8GB (2 x 4GB) DDR4-2400 Memory ($118.99 @ PC Canada)
Video Card: MSI - GeForce GTX 1050 Ti 4GB Video Card ($201.99 @ PC Canada)
Case: Deepcool - TESSERACT WH ATX Mid Tower Case ($39.99 @ Newegg Canada)
Total: $655.89
Generated by PCPartPicker 2018-01-02 16:45 EST-0500
If he needs a keyboard, mouse and monitor, you need to tell him to ah heck off. Otherwise, use one of these sites to pick the pieces:
http://www.logicalincrements.com/
https://pcbuildsonabudget.com/best-gaming-pc-build-under-500-dollars-2018
https://pcmasterracebuilds.com/
https://pcpartpicker.com/
Keep in mind that these are basic, entry level specs when you're building in the $5-600 range. When I'm building a basic gaming platform, I start with the Ryzen 3 and 8GB of RAM. Any GPU with 4GB RAM is the starting point. Try to fit an SSD into the unit, even if it's only a 128GB piece. Please use at least a Bronze, 450w PSU: you won't regret it. Shop the sales at Amazon.com and Newegg.com using https://slickdeals.net/deals/computer-parts/ A great way to save money is to use the cheapest, on-sale mATX case you can find. I've built systems using Rosewill mATX cases for as low as $9.95 (US). They work fine, and like anything else, you can upgrade later.
If you're trying to make a profit building an entry-level gaming computer, pretty much forget it. If you're doing this as a favor for a friend, get the money up front, and make sure he appreciates what you're doing for him. And don't forget, Windows 10 costs $100, something no one ever mentions until the very end...
Im just doing it as a favour for a coworker/good friend.
Im going to use the windows 10 media creation tool and then just get a cheap key. I know people have very passionate opinions about getting windows 10 keys but a friend has been rocking one for 2 years and another has been for 1 year so i've had goodluck with it so far.
Thanks for the reply.
Thanks man that Ryzen build looks pretty solid. Im gonna go with that.
Latest posts
