SOLVED - Chromecast Audio No Toslink Signal
Aria1066
75
I have two Chromecast Audio devices powered by the supplied USB adapters connected to the main power supply.
When I turn these devices on, the red Toslink LED shows for about 2 seconds and then turns off so that I cannot use the Toslink connection to my DACs.
The analog connections work OK.
I'm guessing that these Chromecasts are faulty, but in case I'm mistaken are there any ideas as to how these can be fixed?
Factory Reset re-enabled the Toslink
