I am building(First Build) a computer to be used basically as an email and print machine, this is an replacement to an older computer. I tried to salvage some parts from the computer but most of it incompatible. I did find that the ram fit, so I stuck that in when I was building. After I put everything together when I do a first boot, only the fans and power LED go on and I get a continuous beeping from the system speaker. I read the manual and this means a memory issue, so I swapped it with a 4GB stick from my alienware x57 and I get the same problem. I need this computer as soon as possible for work so please help.
Specs: BIOSTAR A780L3C AM3 Micro ATX AMD Motherboard
AMD Sempron 145 Sargas 2.8GHz Socket AM3 45W Desktop Processor SDX145HBGMBOX
Western Digital WD Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive - OEM
Microsoft Windows 7 Home Premium SP1 32-bit (Slim Envelope) - OEM
HEC Vigilance Black 0.5 mm Thickness SGCC MicroATX Mini Tower Computer Case with Dual 8cm Fan, 2x USB2.0 and HD Audio
APEX AL-8250SFX 250W SFX12V Ver.3.1 Power Supply
BIOS beeps:http://www.biostar.com.tw/app/en/support/faq_content.php?S_ID=373
