I'm sorry if this should go into motherboards.
So I installed my CPU into this motherboard: http://pcpartpicker.com/part/gigabyte-motherboard-ga970ad3p
I proceeded to install the Cooler Master's heatsink. It all went fine until I had to put the X-bracket invetween the heatsink and copper pipes and screw them into the holes of the Cooler Master backboard I installed onto my motherboard. I've confirmed that the screws are in the right position and the X-bracket is configured to fit an AM3+ motherboard.
However, when I begin to screw in one of the four screws, its opposite will raise quite a considerable level: http://i.imgur.com/XzLU4cH.jpg
At this point, I am unable to give this screw a few turns to secure it into the socket. I've tried repositioning the bracket and sliding the heatsink around on the CPU, but it never seems to work. I'm afraid of applying too much pressure and breaking something on the board.
This is slightly urgent because I applied the thermal paste and attached th actual heatsink about an hour ago and I have been trying to get it to work since. Any suggestions? (Sorry for lack of adequate tagging, I'm on mobile)
EDIT: I came back after a few hours of being occupied elsewhere. I think the issue has something to do with the elevation of the bracket after placing the heatsink on top of the CPU. I removed my original thermal paste and tried the bracket alone, as well as some different positions for the heatsink, and this seems to be the case. It would seem that I'd need to press down on the bracket as a whole while inbetween the heatsink and the copper wire plate in order to secure the screws into the standoffs, but I don't know how this can be done without deformity. See this image of one of the screws just hovering above the hole for reference; it's the same for all four: http://i.imgur.com/c32Q8al.jpg
