Windows 7 Desktop running great - new install. Somewhere in the process, the second partition was labeled as the boot drive, C: . In Disk Management, it shows D: as the first partition, which is just a data partition with little on it, then C: which is the boot partition. It runs fine, but I think somewhere down the road this might cause a problem; even if not, I'd like to correct this.
What's the easiest way to do this?
Could I just delete D: and then create a new partition, name it D: and then it will be second in order on the
