Hello. So I tried to build a new PC from a scratch yesterday. After I put all the things together, the computer just won't start at all. I really don't know what's wrong. Is there a chance that the PSU is damaged somehow? I double-checked all the cables, I tried to swap the POWER SW and RESET SW to see, if the POWER SWITCH cable isn't damaged. I also tried to turn on the mobo with screwdriver. But still with no success. Even the PSU Fan won't turn on.
So these are the components:
AMD A10-7870K Black Edition Low Noise Cooler [APU]
GIGABYTE F2A88X-D3HP Motherboard
Kingston 8GB KIT DDR3 1866MHz CL10 HyperX Fury Red Series RAM
AKASA Venom Voodoo Cooler
Fortron Hyper S 700 PSU
The other things like HDD,Case, etc., are not important, cuz I am unable to start PC at all just with all the necessary things connected.
Here I'm including some photos:
[I must only post links, cuz it tells me here that I don't have verified account.. But in acc settings I have marked it as verified .. :I nvm]
So I'm in "Test Mode" as I said just with all the necessary things connected:
http://i.imgur.com/thu5LcH.jpg
There is the ATX cable connected to the mobo:
http://i.imgur.com/xBs55pn.jpg
The ATX 12V cable is also connected same as the CPU FAN cable.
http://i.imgur.com/0ywFO1u.jpg
And there are the Front Panel connectors:
http://i.imgur.com/TiYofmU.jpg
I'm really confused, how can I determine the problem?
I would be really thankful for any help.
If I forgot to post something important, just tell me.
Thank you in advance for any suggestions.
Have a nice day.
Have a nice day.
