EDIT: SOLVED - I checked every connection and reseated the RAM modules, everything is working well again!
Hi,
I have a problem with my older PC not outputting anything to my monitor and I would be very happy if someone could help me. I built this PC myself in 2017, here are the specs:
My problem now: both the GT 1030 and the HDMI port on the mainboard won't output anything via HDMI after I put in the GPU. I removed the 1030 after it wouldn't show any picture and plugged the display directly into the mainboard again - no picture either. (I was about to check for certain BIOS/UEFI settings in regards to output the display via dGPU/first PCIe slot)
I removed everything that isn't needed, tried another display, tried another HDMI cable, did a CMOS reset via battery/jumper - no luck. And now I'm stuck and in need of help. The same pc-display-cable-port combo was working only hours ago. Both displays and HDMI cables are working fine with other devices. The 1030 is spinning up, as do all the other fans. The LEDs on the mainboard indicate that there is power - the system itself seems to be running.
Right now there's only a keyboard and a HDMI cable plugged in, no HDD, no NVMe SSD, no GPU, no additional fans. What are my options here? I thought about flashing the BIOS via USB and to test the RAM modules one by one, but I guess there's something obvious I'm missing here.
Thanks in advance, I'd appreciate all the help I can get.
Hi,
- Intel i5-7500 CPU
- Asus Prime H270M-Plus MB
- Corsair Vengeance LPX DDR4-2400 RAM
- Be Quiet! Pure Power 400W PSU
- Asus GT 1030 GPU
- Samsung EVO 960 SSD
- WIN 10 with latest updates
